Product Spotlight: Ball/Leadscrews
Leadscrew assemblies
Line of leadscrew assemblies includes acme leadscrews, advanced coatings, and anti-backlash nuts to minimize lost motion while maximizing system stiffness.
Features & benefits
Diameters range from ⅛ to ⅝ in. with leads as fine as 0.012 in. and fast leads to 1.25 in.
Rolled from precision ground 303 stainless steel
Come with Black Ice coating, a PTFE process that eliminates flaking
Technical catalog highlights leadscrew assemblies and anti-backlash nuts
Haydon Switch & Instrument Inc.
(203) 756-7441
www.hsi-inc.com
Circle 151
Roller pinion system
Precision roller pinion system is an alternative to precision ballscrews, converting rotary motion into precise, backlash-free linear motion.
Features & benefits
Bearing-supported rollers mesh with optimized tooth profiles, achieving smooth, trouble-free motion
Accurate positioning speeds to 660 m/min
Low friction design minimizes heat and wear
Segments of rack allow the system to be configured for any length
Nexen Group Inc.
(651) 286-1054
www.nexengroup.com
Circle 152
Rolled ballscrews
Grade C10 metric rolled ballscrews come in low-dust raise greased versions in threaded outer diameter 10, lead 4 sizes.
Features & benefits
Induction-hardened for rigidity and long performance
100 to 318 mm lengths available; configurable in 1-mm increments
Carburized nut or induction hardened thread shaft with phosphate coating available
Shaft supports, actuator drives, and linear motion units available
Greasing keeps dust raised to a minimum
Misumi USA
(800) 681-7475
www.misumiusa.com
Circle 153
Self-locking leadscrews
Non-ball leadscrews for vertical applications self-lock and prevent backdriving, without an external brake.
Features & benefits
Diameters from ⅛ to 15/16 in. with leads from 0.02 to 3 in.
Sliding friction between nut and screw converts rotary input motion into linear output motion
303 stainless steel; easily machined without being hardened
Accuracy comparable to ground ballscrews
Kerk Motion Products Inc.
(603) 465-7227
www.kerkmotion.com
Circle 154
Miniature ballscrews
KSS miniature ballscrews come in 224 different ground configurations with finish end machining.
Features & benefits
SG series has diameters from 4 to 14 mm and leads from 1 to 15 mm
SG comes with C3 and C5 precision classifications and travels to 490 mm
SR rolled screw series comes in diameters from 5 to 14 mm and leads from 1 to 20 mm
SR comes with C7 and C10 grades and travels to 400 mm
SD bi-directional series comes in right and left-hand threads
The Precision Alliance
(803) 396-5544
www.tpa-us.com
Circle 155
