Supreme 10HTFL one-component, flexible, epoxy-resin based adhesive and sealant works from 4K to 350°F. It adheres to aluminum, steel, and other metals, as well as fiber reinforced composites, most plastics, ceramics, glass, and wood. Its tensile lap shear strength is over 2,000 psi, and its T-peel strength is over 40 pli when bonding aluminum.
Supreme 10HTFL resists severe thermal and mechanical shock and vibration, as well as water, salts, oils, fuels and organic solvents. It is electrically insulative.
Supreme 10HTFL stores at room temperature for extended periods and does not require mixing prior to cure at 250°F or above. Supreme 10HTFLND2, a non-drip version, is also available.
Master Bond, Inc., 154 Hobart St., Hackensack, NJ 07601, (201) 343-8983, www.masterbond.com, www.masterbond.com/lp/tabs/tp_pp_highpeel.html
Jessica Shapiro
