It sends a signal from the cycle count valve to a PC, PLC, relay, or switch after each cycle completes. The signal can also be interpreted by data-acquisition centers for automated input. The controller can then regulate a valve on the air line or fluid discharge line based on a number of cycles. With the cycle count valve, the number of cycles can be monitored from any workstation networked with the cycle counter.
All-Flo Co., 9321 Pineneedle Dr., Mentor, OH 44060, (440) 354-1700, all-flo.com
