Coolant Pump
Model 9065 182MM industrial coolant pump has been redesigned to improve flow and volume.
The pump features 356-T6 aluminum construction with discharge above the mounting plate, and a mounting bracket incorporated into the design. It is available in single and three-phase versions and 50 or 60 Hz at 0.75 hp. Flow rating is 5 gpm at 65 ft and 25 gpm at 15 ft, 60 Hz. Uses include coolant pump-back systems, filtration systems, cabinet washers, and machine-tool applications.
Gusher Pumps,
115 Industrial Dr., Williamstown, KY 41097,
(859) 824-3100, www.gusher.com
