Looking Back 01/14/2010
Jan. 12, 2010
Devil of a connector: By combining several valve and internal hose connections into one product, Colder Products Co., St. Paul, Minn., was able to help simplify the water/soap distribution system in Cleveland-based Royal Appliance Mfg. Co.’s Dirt Devil Easy Steamer deep cleaner.
10 YEARS AGO — 2000
Devil of a connector: By combining several valve and internal hose connections into one product, Colder Products Co., St. Paul, Minn., was able to help simplify the water/soap distribution system in Cleveland-based Royal Appliance Mfg. Co.’s Dirt Devil Easy Steamer deep cleaner. The original product had separate water/soap distribution valve and connector hose fittings as well as connector hoses and clamps.
30 YEARS AGO — 1980
Solder loaded into cordless gun: Soldering electrical connections is now a one-hand job with the new rechargeable Iso-Tip Cordless Soldering Gun from Wahl Clipper Corp., Sterling, Ill. From a supply chamber at the rear of the gun, 0.062-in. solder is channeled through a tube to the tip when the trigger is fully depressed. Up to 125 electronic joints can be soldered on a single charge; the gun recharges in 4 hr. Cycolac-brand ABS engineering thermoplastic, Grade T from Borg-Warner Chemicals was used for the injection-molded gun case to provide it with high impact resistance.
50 YEARS AGO — 1960
Renault gives Caravelle new suspension: Air bags and rubber pads supplement conventional coil springs and shock absorbers in Renault’s classy Caravelle. Their action gives the rear-engine (water-cooled) import virtually uniform riding qualities regardless of passenger payload. Air bags (air is contained at atmospheric pressure) augment the rear springing; rubber pads surround the front shock-absorber rods. Flexibility of these components decreases rapidly as the load increases to keep the entire suspension system “in tune” with the load.
June 27, 2025
June 25, 2025
June 25, 2025
