New Product: Adhesive Rolls, Sheets With No Edge Curl
Hot and cold adhesive tapes up to 60-in. wide can be laminated, slit, and rewound on one machine.
March 20, 2008
Use of a new heat-lamination system permits the rewinding of pressure-sensitive adhesive products, rolls, and sheets. Full contact with the 180° round drum eliminates edge curl from the material’s.
Greene Rubber Co.
20 Cross St.
Woburn, MA 01801
(781) 937-9909
greenerubber.com
