From Data to Decisions: The Race to Make Industrial AI Operational
For years, the Industrial IoT fixated on the singular idea of connecting everything. Investments centered on connecting machines via sensors and aggregating data to give operators greater visibility into operations. And for a while, that was enough.
Visibility, it turns out, is table stakes. That phase is now giving way to a more consequential competitive divide focusing on what happens after data is captured. Call it digital intelligence.
Now, the challenge is to turn raw signals into real-time decisions. Technologies such as intelligent edge analytics, anomaly detection and live digital twins help organizations understand, predict and respond as events unfold. Capturing the data has become relatively straightforward. Turning that data into operational decisions is the bigger challenge.
The frontrunners are designing systems that connect operational data directly to decisions and responses. “The ones moving ahead design their systems around operational decisions from the start: what action needs to happen, by whom and within what window,” said Sunthar Subramanian, Director of Retail & Consumer Goods – IoT & Sustainability, Cognizant. “It’s a shift we see repeatedly in asset-intensive environments—where frameworks like APEx (Cognizant’s Asset Performance Excellence framework for industrial IoT) have evolved precisely to close that gap, tying sensor data directly to outcomes like uptime, throughput and energy cost, rather than just surfacing anomalies for someone to chase.”
Sunthar, who works closely on systems designed to help industrial organizations translate operational data into timely action, said manufacturers are rethinking the fundamental logic behind industrial alerting systems. “Instead of treating every signal the same, they focus on impact—what matters right now, given production state, asset criticality and downstream risk,” he said.
How Industrial AI Is Moving from Pilots to Production Deployment
The shift may appear subtle, yet it is emblematic of an architectural change underway across industrial operations, where intelligence is moving closer to the asset. With this shift, anomalies can be evaluated and acted upon in seconds, rather than minutes.
“Enterprise IoT systems make this possible by embedding contextual logic at the edge, where some actions execute within defined guardrails and others are escalated for human judgment,” noted Sunthar.
The design goal has shifted from notification to intervention, with systems designed to intervene early enough to prevent disruptions from propagating across production, energy usage or supply flows.
From Alerts to Autonomous Action in Industrial Systems
That transition was evident across the Hannover Messe 2026 show floor, where exhibitors emphasized systems capable of action rather than pitching incremental improvements in alerting. “One global automation provider demonstrated closed-loop, AI-driven optimization adjusting production parameters in real time, keeping humans in the loop only for critical decisions,” recalled Sunthar. “The show’s own tagline this year was ‘Out of theory. Into application.’ That captures exactly where the industry is right now.”
If the industry's focus is shifting from identifying problems to responding to them, the next question becomes what kind of digital infrastructure makes that possible.
What Makes a Digital Twin Actionable (Not Just Visual)
The next phase of this evolution is emerging through what Sunthar describes as live operational models that simulate scenarios, predict outcomes and increasingly influence how systems behave.
If systems are going to act, they first need an operational model capable of understanding what’s happening. A sticking point with most digital twins today is that they still function as visualization layers that help operators see what’s happening. Their ability to determine what happens next, however, remains limited.
“A genuinely live operational model reflects real-time asset state, carries an understanding of process behavior, can test ‘what-if’ scenarios before they touch the floor, and—critically—can write back to control systems and act,” said Sunthar.
That distinction separates a display from a true decision platform. “One of the clearest production-scale demonstrations at Hannover Messe came from a leading industrial OEM [Siemens] that showcased a digital twin unifying 3D layouts, live IoT streams, simulation models and facility data into a single governed environment—running on top of existing tools without forcing a platform migration.”
READ MORE: AVEVA World 2026: Kim Custeau on AI, Hybrid Operations and Industrial Digital Twins
The industrial automation provider demonstrated its Digital Twin Composer platform, built with NVIDIA and deployed with PepsiCo. Instead of figuring things out on the shop floor, teams simulate and validate scenarios in a virtual environment first. Essentially, PepsiCo uses digital twins and AI as co-design tools to evaluate multiple configurations and lock in optimal systems designs before anything goes live.
The ROI is measurable. Siemens reports the approach helped identify 90% of potential issues before physical modifications, reduced capital expenditure by 10 to 15%, and avoided downtime costs exceeding $1 million per hour.
Closed-loop, bidirectional control is undergoing a similar architectural shift. “AI-enabled variable frequency drives (VFDs) are a direct example,” Sunthar said. “Rather than running pumps or fans on a fixed schedule, the system continuously reads pressure, flow, temperature and process demand and adjusts motor speed in real time.” This transition from static scheduling to demand-driven control has delivered consistent double-digit energy reductions.
A similar pattern is emerging in facilities management. Live operational model of HVAC, energy and occupancy can continuously optimize performance rather than simply report it. “That’s a digital twin doing something—not just showing something,” Sunthar said.
Barriers to Scaling Industrial AI Across Multiple Sites
Despite the momentum, enterprise adoption remains uneven. Sunthar points out that the gaps are structural, starting with what he describes as uneven data foundations. One plant’s baseline is another plant’s blind spot. Inconsistencies in equipment, fragmented control systems and uneven instrumentation make standardization elusive. “Plants differ widely in equipment age, control systems and data maturity—what’s instrumented at one site often doesn’t exist at another,” he said.
The second barrier is the lack of a reusable deployment model. Too many organizations still treat each rollout as a one-off. In contrast, leading manufacturers standardize early. “They baseline asset archetypes early, identify which equipment families behave similarly across sites and templatize the sensing, modeling and response logic into reusable frameworks,” he said.
“That turns a 12-month plant deployment into a six-week configuration exercise. We see this work consistently across global consumer goods process manufacturers, where a templatized smart manufacturing approach has saved thousands of person-hours per program and delivered ROI well within the first year of each rollout—because the accelerator templates eliminated repeated reinvention across sites.”
The third barrier is organizational. Data ownership, infrastructure management and operational accountability are often fragmented across silos. Scaling AI, Sunthar argues, requires “shared ownership of results, not just shared access to a platform.”
How to Close the Gap Between Data, Decisions and Action
If the goal is to reduce the time between detecting a problem and resolving it, it is fair to ask whether that trajectory ultimately leads to autonomous operations.
Sunthar believes it does, but not in the way that many vendors suggest. Meaningful autonomy doesn’t come off the shelf and rarely does it emerge from a single software. Instead, it emerges from purpose-built architectures designed around a facility's existing operational systems, data flows and decision-making processes. In other words, autonomy is less a technology purchase than an engineering challenge—one that depends on how effectively data, controls and business systems are connected across the industrial stack.
READ MORE: How AI Transforms Fragmented Data into Actionable Engineering Intelligence
“Autonomous response requires AI that can talk across the full operational stack—from warehouse execution systems (WES) and warehouse control systems (WCS), through manufacturing execution systems (MES), up to ERP and enterprise planning layers,” said Sunthar. “No single product does that out of the box. It takes agentic system design: AI agents with defined roles, decision boundaries and handoffs, built to orchestrate actions across those layers in sequence and in real time.”
Agentic AI extends beyond assistants by pursuing goals, making decisions and executing tasks across systems. It coordinates actions with minimal human input. Over time, this model evolves into networks of specialized agents to execute tasks based on human intent.
How Agentic AI is Orchestrating Industrial Workflows
This shift toward orchestration is now emerging in industrial systems through agentic design.
A reference example is Siemens’ Eigen Engineering Agent, an external application that works closely alongside TIA Portal, the platform engineers use to design and configure factory equipment. The generative AI-powered assistant is designed to streamline tasks such as PLC coding, HMI configuration and project setup. Eigan evolved from customer feedback, particularly answering a need to save time on PLC coding, explained Girish Arunagiri, Senior Principal, Product Management, Siemens.
Eigen, distinguishes itself from other chatbots by iteratively correcting errors and understanding project context, including function blocks and I/O connections. In one demonstration, it added a welding station to an existing project, created a controller, implemented quality checks, generated a test plan, and summarized the results for handoff.
Eigen’s agentic layer is designed to act, not just respond, said Arunagiri during a media interview at Hannover Messe. Rather than returning a single answer, the system generates a plan, writes code, tests outcomes and iteratively corrects errors. “It reacts to the plan, it essentially reflects on what it created, and when it sees a compilation error, it will go back and iteratively correct it,” he said.
Siemens has piloted Eigen with more than 100 companies in 19 countries. In the U.S., Prism Systems used it to create, modify and import SCL code in seconds. “The challenge has been bringing that capability into real industrial workflows,” said John Elias, President at Prism Systems. “Siemens’ latest tools help close that gap, allowing us to apply AI in a way that truly supports engineering and automation.”
While the breakthrough is notable, its transformative potential lies in the architecture it enables—the ability to orchestrate decisions across interconnected systems. As routine tasks become automated, engineers can focus on more complex system-level challenges. Siemens reports the agent executes AI-powered workflows two to five times faster than manual approaches, improves solution quality by up to 80%, and raises engineering efficiency by 50%.
What it Takes to Move Industrial AI from Pilot to Scale
Gartner reported that by the end of 2025, at least 50% of generative AI projects were abandoned after proof of concept due to poor data quality, inadequate risk controls, escalating costs or unclear business value. The finding suggests that the challenge facing many organizations is not AI technology itself, but the ability to operationalize it at scale.
That raises a another question for industrial enterprises: What separates AI initiatives that remain trapped in pilot mode from those that evolve into trusted, production-grade systems capable of supporting operational decisions?
Sunthar said a mature AI operating model is clear about four things: which decisions AI supports, where humans stay in the loop, how models are monitored and retrained, and who is accountable for outcomes in business terms. “What’s almost always missing early is that last one,” he said. “When AI is treated as an IT initiative, it tends to plateau in pilot mode. When it’s owned by the leaders responsible for yield, uptime or cost—and success is measured in those terms—it scales.”
READ MORE: Beyond the Sticker Shock: The Real Reason Companies Hesitate to Adopt Robotics
If this diagnosis holds, the implication is clear: Autonomy is not a standalone technology upgrade, but an outcome of how effectively industrial systems are integrated and governed. Fragmented systems, unclear decision ownership and siloed accountability continue to slow adoption. In this context, execution speed (how quickly organizations can move from sensing a condition to taking action) becomes a defining competitive differentiator.
In Sunthar’s view, many companies undermine AI initiatives before they reach scale. They are chasing the destination before building the road to get there. The journey has three phases: The first phase focuses on targeted productivity gains, proving value in specific use cases. The next phase—industrialization—integrates AI across the stack, standardizes data and treats model performance as an operational responsibility. The third phase introduces AI agents to orchestrate decisions across the enterprise.
The common misstep is skipping the industrialization phase in favor of premature autonomy. The industrialization phase is where measurable value is realized at scale, pointed out Sunthar. This architecture-first approach is reflected in large-scale deployments such as Cognizant’s smart manufacturing work with a global industrial tools manufacturer, where more than 100 plants and roughly 1,000 machines were connected through a cloud platform without disrupting operations. The program delivered approximately $200 million in value over three years by shifting IIoT from monitoring to enterprise-wide operational decision-making.
Trust also remains critical. “Operators don’t resist AI because they don’t understand the technology; they resist when the system makes decisions they can’t see into and can’t override,” said Sunthar. “Designing explainability and human override into the architecture from the very first pilot—not bolting it on later—is what makes autonomy trustworthy rather than threatening.”
What it Boils Down to for Design Engineers
For all the attention being paid to AI, digital twins and autonomous operations, the real competitive divide is increasingly clear. The organizations pulling ahead are those building the architectures, workflows and accountability structures that allow insight to become action.
For design engineers, that shift begins much earlier—in decisions about sensors, controls, connectivity and interoperability that determine not only whether machines can participate in a larger operational ecosystem, but how effectively they do so. As Sunthar observed, “Trust in AI follows demonstrated value and demonstrated value requires someone accountable for the outcome, not just the deployment.”
Editor’s Note: This article is part of Machine Design’s summer reading series exploring global design engineering trends redefining how products are conceived and scaled.
In This Series:
- From Data to Decisions: The Race to Make Industrial AI Operational
- The Coming Shift: Why Industry 5.0 Will Be Driven by AI in Mechanical
- Will AI Replace Programmers? What Elon Musk’s Prediction Means for Mechanical Engineers
- Q&A: The AI-Robotics Convergence: Global Perspectives for Machine Builders
- The Robots Are Getting Real: Lessons from Hannover Messe’s Industrial AI Reality
- How Augmented Reality is Changing the Way We Design Machines
Rehana BeggRehana Begg
As Machine Design’s content lead, Rehana Begg is tasked with elevating the voice of the design and multi-disciplinary engineer in the face of digital transformation and engineering innovation. Begg has more than 24 years of editorial experience and has spent the past decade in the trenches of industrial manufacturing, focusing on new technologies, manufacturing innovation and business. Her B2B career has taken her from corporate boardrooms to plant floors and underground mining stopes, covering everything from automation & IIoT, robotics, mechanical design and additive manufacturing to plant operations, maintenance, reliability and continuous improvement. Begg holds an MBA, a Master of Journalism degree, and a BA (Hons.) in Political Science. She is committed to lifelong learning and feeds her passion for innovation in publishing, transparent science and clear communication by attending relevant conferences and seminars/workshops.
YouTube: @MachineDesign-EBM
Related
dreamstime_m_333004440Voice Your Opinion!
