Cushion Mounting Tape
The R/bak SA 3000 cushion mounting tape is for wide-web flexible packaging printers. Designed with the company's open-cell urethane cushion technology and a specially developed acrylic adhesive, the tape is said to help eliminate problems on press and permit easier printing on rough surfaces, as well as reduce gear banding and press bounce.
A transparent liner minimizes air bubbles and makes tape lay down easier. The tape's adhesive system allows for quick repositioning of the tape and plate in the printing process.
Rogers Corp.
One Technology Dr.
Rogers, CT 06263
(860) 928-8926
rogerscorporation.com
